Community Member
CSCsm66330 /LMS 3.1
This bug is still existing when it has been upgraded to LMS 3.1.Initially, the bug was installed under the version LMS 3.01.The default is coming back and i beleived it was keeped , when it was restored.
Does someone has an idea about a special method? Do we need to open a SR to the TAC due a the environnement of variable ?
Community Member
Re: CSCsm66330 /LMS 3.1
You can try to make a hosts file from the export from the DCR.
Once the name can be resolved the host wont be added again. Whether this is DNS or a local hosts file is just the same
cheers,
Michel
No, this bug should no longer exists. The way it was solved was to poll the ipAddrTable of the devices to determine if a device was already in DCR. If you have an SNMP view which is blocking the ipAddrTable, then that could cause duplication. There may also be a problem with the DCR properties of your existing devices. Post all of the DCR attributes of two duplicate devices.
Community Member
Hi Joe,
I work with Richard.
You can find 2 duplicates devices with DCR attributes.
Elisabeth
137
