CSV file format issue
I have exported an inventory csv file, my plan is to update the file and add/edit/delete devices and then import back to RME 4.0.5. When I try to save it doesn't let me save into csv format, is it safe to save it in XL format work it through and then save it back to CSV and import it? Thank you all in advance.
1 REPLY
Re: CSV file format issue
I don't understand the question. What error do you get when trying to save to CSV format? The export mechanism for XML and CSV work the same way. I guess I'm trying to figure our how you plan to modify an XML file then save it in CSV format.
115
