06-18-2009 05:36 AM
I try to discover with CUOM 2.1 an CM 7.0 on a VMWare-ESX server in our showroom. The Communications Manager state is unreachable. SNMP and HTTP Username/Pwd is correct configured in the CM and in the OM.
Do anybody has an idea?
Thanks for any input.
Kind regards
06-24-2009 06:13 AM
Devices may go into the Unreachable state due to the following reasons:
⢠SNMP timeout
⢠Data Collector timeout
If an SNMP timeout occurs, verify the SNMP access credentials provided during discovery.
If a data collector timeout occurs, verify that the SNMP management interface is not a serial or a generic interface (such as Framerelay with the subnet mask 255.255.255.252). You should always access SNMP details using an Ethernet interface.
10-02-2009 08:23 AM
Did you ever resolve this issue? I've just built CUOM 2.2 running against a 7.0.2.
CUOM discovers the Publisher and Subscriber but the service view shows the publisher as unreachable, which I don't understand as it's the same config as the subscriber.
Jed
10-05-2009 12:35 PM
No workaround for this problem, sorry.
