06-27-2012 06:20 AM
Hi Guys,
My Customer will do upgrade CUOM 2.3 to 8.6 and have the following doubt, about the hardware/software requeriment
Hardware
- 4 vCPUs
· 16 GB de memória
· 100 GB de HD
Software
· Windows 2008 32 bits
Virtualization
- VMware ESXi 5.0.
This setup is correct? Are there support ESXi 5.0 to version CUOM 8.6?
Wilson
Solved! Go to Solution.
06-27-2012 11:10 AM
Hi Wilson,
I found this in the install guide.
"Operations Manager supports VMware ESX 3.5 and ESXi 4.x. Operations Manager must have the same system resources available to it, inside the virtualization environment that it has for a standard (nonvirtual) installation."
06-27-2012 09:24 AM
06-27-2012 09:57 AM
Hi ngoldwat,
I had already to saw the 03 links that You recommend. Not is clear that CUOM 8.6 is supported about ESXi 6.0, can be not is mentioned the requirement hardware that I showed above.
Wilson
06-27-2012 11:10 AM
Hi Wilson,
