Customize Email Notification in Cisco Works
hi there!!!
how to customise Email notifation so that the helpdesk can interpert clearly.
the current alert notication mail is as below
I want to get ride of alert ID in the subject. Inplace of ip address i want device name
subetct Fwd: 00000RW ; 132.2.90.251 ; Wed 06-Sep-2006 14:28:25 BST ; Critical ; Utilization ; Active
ALERT ID = 00000RU
TIME = Wed 06-Sep-2006 13:14:02 BST
STATUS = Active
SEVERITY = Critical
MANAGED OBJECT = 10.156.63.254
MANAGED OBJECT TYPE = Switches and Hubs
EVENT DESCRIPTION = 10.231.102.254 [10.156.63.254]:Unresponsive ; IF-10.156.63.254/17 [FastEthernet9/0/3] [10.155.159.254, ...] [pid123]:HighUtilization; 10.201.102.254 [10.156.63.254]:Unresponsive ; 10.201.47.254 [10.156.63.254]:Unresponsive ; 10.156.63.254:Unresponsive ;
CUSTOMER IDENTIFICATION = Datanetworks
CUSTOMER REVISION = 1
Re: Customize Email Notification in Cisco Works
You can change the description for each notification and when you customize an event name, that name is reflected in all notifications, on the Alerts and Activities display, and in Fault History.
The new event name is used for all instances of an event, regardless of the component on which the event occurs.
Here are the steps:
1. Go to DFM > Notification Services > Notification Customization.
2. Select the event names you want to customize by clicking the check box beside each event name.
3. Enter your new names in the New Event Description fields.
4. Click Save new descriptions to save your changes but not apply them to the DFM displays
or
Click Apply saved descriptions to apply your changes to subsequent DFM displays. When the
confirmation window appears, click Yes, and your changes will be applied to DFM.
I did Customization but still i am getting the Alert ID 00000RY...
Subject 00000RY ; 10.211.61.254 ; Wed 06-Sep-2006 15:50:45 BST ; Critical ; Utilization ; Active
how do i get ride of ip address i want Dvice name ( which is applied via DCR )
150
