CVDM 1.1 on 6509E
Trying to CVDM on a 6509E running:
S72033_rp, s72033_rp-PK9SV-M, version 12.2(18)SXD6
PC is running XP Pro, IE6, Sun JRE 1.5.0_06-b05
Getting problems loading diceloader.jar:
java.net.SocketException: Unexpected end of file from server.
Have tried this on two 6509E both have same error. The PC is used for CNA, Ciscoworks, ADSM so I know the java etc. is good.
Any ideas??
Re: CVDM 1.1 on 6509E
have you tried this from another PC? Also, is this CVDM 1.1? and do both switches have the same version of code running?
yes and yes!
114
