Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CView Device Package - Rtr 3800
Initially i was not able to add the Cisco Router 2800 & 3800 under the Device & Credentials > Device Management. In the Select the Device Type database these router were not displayed. I installed the Service Pack CS 3.0.2 from 3.0 and REM 4.0.2 from 4.0. After installing the Service Pack, i am able to view the 2800 & 3800 series routers in the Select the Device Type under Device Management, and sucessfully configure the SNMPv3 RW access for 3825 router. But not able to view the Chassis under Cisco View 6.1 for the 3825 router. It pops up an error; *
Can't find applicable device package for 128.200.199.149.*
I have also installed the Cisco View Device Package for Router 3800, downloaded from CView Planner site. But still no progress.
SNMP config on the router:
snmp-server group BELCommunity v3 auth write BELView notify *tv.FFFFFFFF.FFFFFFF
F.FFFFFFFF0F
snmp-server view BELView mib-2 included
snmp-server view BELView products.543 included
snmp-server community private RW
snmp-server enable traps snmp linkdown linkup
snmp-server enable traps syslog
snmp-server host 128.200.199.199 inform version 3 auth BELTest1
Can any one help me, in solving this casee.
Keshava Raju
HP India.
1 ACCEPTED SOLUTION
Re: CView Device Package - Rtr 3800
Tell me, you used the GUI from the LMS to upgrade software. I mean, you used the CS -> Software upgrade ?? and next you upgraded the CiscoView.. you choose the directory where the two packages (NGMARShare.cv50.v1-1.zip) and the (Rtr3800.cv50.v8-0.zip) the two files have to be in the directory. you started with the first.
You have to pay attension, after upgrading the first one you have to wait for more than 5 minutes, the time for the CiscoWorks Deamon to reload all services, than you do the second.
please, tell me if that the right steps you followed??
PLEASE RATE IF THAT HELP
Silver
The current version of Common Services is 3.0.5 and Ciscoview is 6.1.5.
Have you installed all of the MDF and IDU's ?
MDFs and IDUs is how Cisco adds support for new devices. Current MDF version for 2.6 is 1.21
If you go into Common Services, Software Center and Device update you can click on the product name and it will show you whats installed.
For Ciscoview the current version is 8.0 for both 2800 and 3800's.
Hi Mr. Andy,
Many thanks for your responce to my query.
I have installed the Common Services 3.0.4 which upgraded the ciscoview from 6.1 to 6.1.2. I downloaded the CS 3.0.4 from the site http://www.cisco.com/pcgi-bin/tablebuild.pl/cw2000-cd-one , but CS 3.0.5 is not found here in this list.
Can you please guide me on ho to download the CS 3.0.5 and CiscoView 8.0
However i can see the Devices Router 2800 & 3800 under Common Services>Software Center>Device Update>CiscoView 6.1.2.
The problem you have to show the router on CiscoView is not to update, but to download the package. to do so, you need to have CCO privilage to do that.
Go to this link, you chose the version of CView and then download the package.
http://www.cisco.com/pcgi-bin/Software/CiscoView/cvplanner.cgi
or go to :
http://www.cisco.com/cgi-bin/Software/CiscoView/cvplanner.cgi
Remember, don't need to upgrade from 6.1 to 6.1.2 but you have to download the following files:
Do the first before, and use the Web interface to upgrade.
This on can help:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_ciscoview/6.1.5/user/guide/ug_7.html
Hi Mr. Omar,
I installed the above said patch and the Device Package. But still, CView do not display the Router View. I am not able to view the Router under Mini RMON aswell.
Keshav
Mr. Omar,
Thank you very much. I had installed the CView 3800 package first (Rtr3800.cv50.v8-0.zip) and then installed the NGMARShare.cv50.v1-1.zip.
Uninstalled the 3800 package and reinstalled the package. It is working absolutely fine...
Keshava Raju.
keshava-p.raju@hp.com
Can you enable CiscoView debugs to see what is happening in the background?
I noticed from your config that you don't have an snmp RO comm string which CiscoView needs...do you have this configured?
Also, minirmon will not work with you 3800...not a supported device
About Minirom, I didn't use it before.
But about CiscoView Packages, you follow the steps that I told you.
You can monitor services using the Services availible on Windows and refresh if each few seconds.
247
