CW LMS 2.5 problem
My device display name always reset back to ip address.
This mean from Common Services>DCR i will always see device ip address instead of display name i have insert before.
Re: CW LMS 2.5 problem
Were the devices initially added to the DCR via IP address? Do they resolve properly forward and reverse via nslookup?
I've run into this issue before. I found that if the reverse lookup does not work, then I will only see IP addresses for the device names. You need to make sure that the IP address resolves to a name.
Thanks a lot and i will try
94
