CW LMS 2.5 Syslog Messages
Hi All,
I am trying to setup a Cisco VPN 30xx Concentrator to send its syslog messages to our CW server but so far I am unsuccesful, can anyone give me some hints or ideas what might be causing the problem, Thanks.
1 ACCEPTED SOLUTION
Re: CW LMS 2.5 Syslog Messages
Are the messages actually hitting the server (the log file)? Can you try to generate a syslog message and perhaps do a packet capture to see if the message is reaching the server?
Not sure what version of RME you are running, but you might want to make sure the concentrator is sending the messages in the correct format.
The VPN3000s use a different Syslog format than
Cisco IOS devices by default.
To make them compatible the Syslog message format needs to be set to Cisco IOS format:
Enable logging on 3000, Configuration>System>Events>General, set Syslog format to cisco Ios compatible, severity to Syslog 1-6.
Then you can check the syslog.log or syslog_info to see if the messages are showing up correctly. If they are then make sure they are managed devices in the RME inventory in order for them to show up in the Syslog Standard reports.
We have RME 4.0.4 installed, I've check the Syslog format and it is configured for Cisco IOS Compatible, Events to Syslog: Severities 1-5. I also checked the Syslog Servers and everything seems to be configured correctly but I still am not receiving any syslog messages.
We have figured out our problem, the syslog messages were not reaching the server, we had our firewall people check the firewall again and they discovered that they hadn't put in the right information. Thanks for all your help.
137
