Community Member
CW LMS 2.6 CISCO VIEW
Hello everybody
The CW found discovered automatic devices, but some devices wasn't discover, then I added this devices manually. I have this problem, when I use the cisco view, some devices can't be management and send me the follow message:
Can't find applicable device package for x.x.x.x
Cause
Device package for this device type is not installed or device support for this device type might not be available or you are attempting to open a component inside a device.
Action
Please install a device package for the device type or open the parent device to manage the component.
I don't undertand this message, can somebody help me for resolve this problem? I need management my devices,
I'll appreciate all the help I can get...
1 REPLY
Re: CW LMS 2.6 CISCO VIEW
look at this thread to find out how to update the device packages for Cisco View:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&topicID=.ee71a02&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cbf30b7
you will need a CCO login to download the device packages.
128
