04-10-2009 10:33 AM
I have difficulty some times on my script to sorted out the cwcli output because each column separated by "space". either any way, the out put column separate by "comma" easily to identify columns?
Thanks.
Solved! Go to Solution.
04-10-2009 11:11 AM
The ut -cli output is also delimited by commas by default.
04-10-2009 10:36 AM
Exactly what command are you running?
04-10-2009 11:00 AM
cwcli invreport -u XXX -p XXX -reportname "XXX" -device %
from script also using
opt/CSCOpx/campus/bin/ut -u XXXX -p XXXXX -cli -query all -layout XXXXX
04-10-2009 11:05 AM
The inventory reports are delimited by commas already.
04-10-2009 11:08 AM
I am sorru I think sent you the wrong one, the one for user tracking.
04-10-2009 11:11 AM
04-10-2009 11:33 AM
thanks J. you are right. there is some script on my system actually convert the csv output from CW to text.that confused me. thank you for confirmation.
