Community Member
cwcli out put LMS 2.6
I have difficulty some times on my script to sorted out the cwcli output because each column separated by "space". either any way, the out put column separate by "comma" easily to identify columns?
Thanks.
1 ACCEPTED SOLUTION
Re: cwcli out put LMS 2.6
The ut -cli output is also delimited by commas by default.
Exactly what command are you running?
Community Member
cwcli invreport -u XXX -p XXX -reportname "XXX" -device %
from script also using
opt/CSCOpx/campus/bin/ut -u XXXX -p XXXXX -cli -query all -layout XXXXX
The inventory reports are delimited by commas already.
Community Member
I am sorru I think sent you the wrong one, the one for user tracking.
Community Member
thanks J. you are right. there is some script on my system actually convert the csv output from CW to text.that confused me. thank you for confirmation.
129
