CWLMS-2.2-K9
What is the difference between these 2 products?
CWLMS-2.2-K9 LAN Managment 2.2 for WIN/SOL; CM, DFM, RME, RTM, CV
and
CWRW-1.3-K9 Routed WAN Mgmt 1.3 for WIN/SOL; ACL, IPM, RME, CV
Thank you.
1 ACCEPTED SOLUTION
Gold
Re: CWLMS-2.2-K9
Hello its two different products.. LMS has different modules (it what abbreviations CM, DFM means) some are used for LAN only (DFM) and some for WAN networks (ACL)
CM - campus manager
http://www.cisco.com/en/US/products
DFM - device fault manager
http://www.cisco.com/en/US/products/sw/cscowork/ps2421/index.html
RME - resource manager essential
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/index.html
ACL - access control list manager
http://www.cisco.com/en/US/products/sw/cscowork/ps402/products_data_sheet09186a0080092440.html
RTM - real time monitor
http://www.cisco.com/en/US/products/sw/cscowork/ps2803/products_data_sheet09186a0080088837.html
CV - cisco view
http://www.cisco.com/en/US/products/sw/cscowork/ps4565/index.html
Those products have same just RME (used for config backup, system upgrades etc..) and CV (used for device viewing )
So basically CWLMS-2.2-K9 LAN Managment is used for LANs and CWRW-1.3-K9 Routed WAN Mgmt is for WAN environment
Hope that helps rate if it does
M.
Gold
Re: CWLMS-2.2-K9
CM - campus manager
CV - cisco view
M.
Re: CWLMS-2.2-K9
Thanks a lot.
252
