CWLMS 3.1 installation recommendation
I would like to receive a recommendation about the installation of CWLMS 3.1 under Soaris 9.
The hardware is the following:
Sun Microsystems  sun4u Sun Fire V890
5 HD with 72Gb each
System clock frequency: 150 MHz
RAM: 8 Gb
Processor: 2 of 1200 MHz, US-IV
I was thinking in doing a RAID to mirror the disks. In this way, I will have a total of 114 Gb available, and one HD will remain without use. It is possible to do other administration?
On the other hand, what type of File System could you recommend me?
I was thinking to put only / con y swap of 16 Gb.
I have to create /var/adm/CSCOpx? which is the capacity? (to store the configs, software images, logs y  job data)
The documentation says "85 GB free space for LMS and HUM applications and data, in the CiscoWorks installation directory— For LMS 1,500, LMS 5,000, and LMS 10,000 device license types and for HUM 1,000 device license types"
Then I create a FileSystem with /opt with 85 Gb?
Thanks very much in advance!
143
