CWLMS delete old running config
i have a CWLMS 2.5 on windows.
I was configured for download a running configuration mensually.
How can delete the olds versions?
I'm interesing only keep the last 3 old running config only, no more.
I attach a screen shot.
Thanks for advance!!
best regard :)
Re: CWLMS delete old running config
Go to RME > Admin > Config Mgmt > Purge Settings, and enable configuration purging based on your requirements. Next, go to RME > Admin > Change Audit > Set Purge Policy, and configure a similar purge policy (how long do you want to retain change records?). Once that's done, you can then go to Force Purge, and force a Change Audit purge.
Finally, you will need to wait for the config purge job to run. Once that completes, your old configurations should be purged.
Jclarke! Thanks 4 your instant answer. I will do this steps, and then i will inform you.
Thanks again :)
268
