CWorks LMS2.5 - Win2003 Svc PK 1
We have Cisco Works LMS 2.5 running on Windows Server 2003 Enterprise Edition. I need to install Service Pack 1 on Windows Server 2003 but I am not sure if it will affect the Cisco Works. Should I stop the daemon manager before installing SVC PK 1 or just go ahead and install it.
Please advise.
thanks,
Ali
  • Network Management
1 ACCEPTED SOLUTION
Re: CWorks LMS2.5 - Win2003 Svc PK 1
It shouldn't be a problem to install SP1 as you would any other time. Just make sure that if it prompts to reboot you shut down everything properly.
I did it in my lab here last week and didn't see any problems
Thanks for a quick response. I have installed svc pk1 and everything seems to be working properly.
Thanks everyone.
Ali
I had the same exact concern about 2 months back, never got a definitive answer. Proceeded with the Service Pack 1 upgrade. Success!!! All systems GO!!!
123
