Daemon Manager is not started after installing LMS 2.6
Hi all!
After installing Common Services from LMS 2.6 packet the Daemon Manager service is not started. When i tried to start this service manually i got next error message:
Error 1053: This service did not respond to the start or control request in a timely fashion
there was no errors when i installed CS. CiscoworksSetupXXXX.log file doesn't contain any error messages.
Please tell me what i need to do
1 REPLY
Re: Daemon Manager is not started after installing LMS 2.6
Check the Windows Event Viewer for any messages. You should also check the server's console if you are doing the administration over remote desktop. The console may have a dialog or other pop-up with indicates what is happening. If that all checks out, please post your syslog.log and NMSROOT\lib\classpath\md.properties.
127
