Webcast-Catalyst9k
DCR export-import 3.0 csv file problem
When I look at the format of the CSV file when I bulk_import or export from/to the DCR with the credential in LMS2.5 there is no entry anymore for user_defined_fields. The online help in LMS2.5 says you can use it in the 3.0 format but the syntax in the .csv itself doesn't specify anything for it. So the various doc's conflict!
What we want is to import the UDF into the DCR via .csv or xml.
Who can help here?
1 REPLY
Red
Re: DCR export-import 3.0 csv file problem
If you want to export the User Defined Fileds, you need to add the UDF names in the Export Format file located at
NMSROOT\objects\dcrimpexp\conf\Export_Format_CSV.xml or Export_Format_XML.xml.
You can find more information on this and some sample CSV and XML Files (having user defined fields) in the Online Help. Also refer the User Guide link which has the information on User Defined Fields export/import:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_d/comser30/usrguide/dcr.htm#wp1057600
http://www.cisco.com/en/US/products/sw/cscowork/ps3996/products_user_guide_chapter09186a008022f961.html#wp1057600
Try adding these into the first block (group):
user_defined_field_0
user_defined_field_1
user_defined_field_2
user_defined_field_3
340
