Yes, this is because Excel 2007 changed how it handles CSV files. We currently have en enhancement request filed to handle what it does to files (CSCsz39156). The workaround is simple. Edit the CSV file in notepad, and remove the lines at the top with are all commas (I believe there will be two). Then the file will import just fine.
