Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
DCR is not able to discover MSFCs (which is discovered previously)
Hi Expert,
I am now facing a problem to discover MSFCs in a few different campus LANs. Those MSFCs are initially discovered (for the first few discoveries upon successful LMS server installation).
However, they are no longer in neither the Reachable list nor the Unreachable list followed by the subsequent discoveries.
A debugging CSDiscovery.log while using ping sweep to discover one of the MSFC IP addresses is posted here.
From the log, I noticed that the device is discarded upon DCR getting the sysName and object ID. Not sure if this is the key problem. Please advice. Thank you very much!
Yi Shyuan
1 ACCEPTED SOLUTION
Re: DCR is not able to discover MSFCs (which is discovered previ
Again, check the credentials for the MSFC in DCR (under Common Services > Device and Credentials > Device Management). Reenter them to make sure they are correct.
At the same time, it can also be noticed that the DCR Display name is the IP Address of the device. Even though Global setting is set to display Host Name in DCR and preferred management IP Address is the SysName, it seems like DCR can only display the IP Address in Device management.
Yi Shyuan
No. This is dependent on the IP address being reverse resolvable in DNS or the server's local hosts file. Verify that 10.71.137.253 is resolvable to a hostname.
As for the Discovery, it looks okay in this log. As with your 6500, make sure the credentials in DCR are still correct for this MSFC. Also, review your Discovery filters to make sure they still allow this MSFC to be discovered.
Since DNS servers in the LANs are not updated and not synchronize among themselves, I suspect the IP address is not resolvable to a hostname.
However, there is not IP Address is excluded in the filter when discovery is done for the MSFC IP Address.
97
