12-07-2007 06:56 AM
Is there any way to prod RME into re-synchronizing with DCR? I recall the last time a few devices with messed-up DNS records were entered into DCR, removing them from RME after DNS got fixed did not make RME re-sync with DCR.
Solved! Go to Solution.
12-08-2007 10:37 AM
To add devices manually from DCR, go to RME > Devices > Device Management > RME Devices. When you click the add button, you will be presented with a list of devices in DCR, but not managed by RME. You can then choose to manage all of those devices in one shot, or pick the devices you want RME to manage.
12-07-2007 12:04 PM
You could try unchecking the box to auto-manage devices in DCR, then apply that change, then re-checking itit.
12-07-2007 12:10 PM
Forgot to say I'm on LMS 2.6. This appears to be an LMS 3.x feature, as I can't find the equivalent in LMS 2.6.
12-07-2007 12:20 PM
No, it has existed since LMS 2.5. It's under RME > Admin > Device Mgmt > Device Management Settings.
12-07-2007 12:29 PM
Thanks, I was looking from the DCR end exclusively.
Approximately how long should I be waiting for the sync to come to fruition? Is there a log that registers the sync activities?
12-07-2007 12:52 PM
RME should attempt to auto-manage all devices in DCR once the checkbox setting has been applied. The EssentialsDM_Server log may give you some details about what it is doing. Other than this setting, you could manually select devices to add to RME from DCR.
12-07-2007 01:09 PM
The problem is the devices (untouched in DCR since the DNS mix-up was external to LMS) simply do not get sync'ed to RME anymore, after half an hour has passed. All I see are the following lines repeated in EssentialsDM_Server.log
[ Fri Dec 07 15:55:11 EST 2007 ],INFO ,[Thread-54],com.cisco.nm.rmeng.inventory
.dm.server.CSTMAPIImpl,UpDateDeviceResult,632,Call back from the App Archive Mg
mt
[ Fri Dec 07 15:55:21 EST 2007 ],INFO ,[Thread-54],com.cisco.nm.rmeng.inventory
mt
I must have missed something. I don't see any option of manually sending devices from DCR to RME.
12-08-2007 10:37 AM
12-10-2007 06:34 PM
It would be better to use DCRCLI to remove the old records from the database, then wait for rediscovery or add them manually.
LMS 2.x has some serious dcrdb issues as it interacts with Campus.
