Community Member
Debug reset
We are using Enable Debug to start debugging on Common Services
Components and according to the User Guide for 3.2 Reset All should Disable All Debugging!
This is not working.
Any sugestions.
Re: Debug reset
This is working for me. Exactly what debug did you enable? What message do you get when clicking "Reset All"?
Community Member
Re: Debug reset
There is no error message but the option does not work.
It is LMS 3.1. I can disable the debug manually.
Re: Debug reset
You should get a pop-up saying that debugging was disabled. Exactly which debugging did you turn on, though? I want to see if I can reproduce doing the exact steps you did.
139
