Community Member
deleted devices still showing up in reports
I have deleted switches recently from Common Services and RME and don't appear when listing devices but they still show up reports such as the DCR ACS Devices List Report in Common Services
1 REPLY
Re: deleted devices still showing up in reports
Exactly which report is this? Are you referring to the "Devices that are not configured in ACS" report? If so, I'm surprised you could delete those devices in the first place as they should not have been visible in any device selector.
Something you might try is temporarily breaking ACS integration to see if the devices still show up in the device selectors when CiscoWorks is using local authorization.
250
