02-02-2006 07:09 AM
Ive accidentally deleted the flash memory in a 1700 series router? How do I get it back?
02-06-2006 12:50 AM
hi
have you executed squeeze command or only delete command ? if you have done only with the delete command try using undelete command to recover them.
But if you have done with squeeze command then you wont be able to recover the deleted file..
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hcf_r/cfn_11h.htm#wp1033799
regds
Log in to Community
