Deleting Databases and Starting Again
Our installation of LMS 3.2 is in a bit of a mess - what I would like to do is to delete all the databases and start again from scratch, but without reinstalling the whole suite.
Is this
a) recommended - or should I just do the fresh install
or
b) something that is easy to do.
Just to make it clear I want to get rid of all the current stuff thats in there (including devices, configs, archives the works) and start with a clean slate
Paul
Re: Deleting Databases and Starting Again
You can do this by reinitialzing the various LMS databases using the dbRestoreOrig.pl command:
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=cmf dmprefix=Cmf
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=rmeng dmprefix=RME
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=ani dmprefix=ANI
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=dfmEpm dmprefix=EPM
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=dfmInv dmprefix=INV
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=dfmFh dmprefix=FH
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=opsxml dmprefix=Opsxml
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=ipm dmprefix=Ipm
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=upm dmprefix=UPM
The commands need to be run in that order.
Blue
Would this be any different from restoring a copy of the dbbackup taken after a fresh install?
If the backup was taken after install without doing ANYTHING else in LMS, then yes.
Worked a treat - thanks for that.
209
