deny router command on priv level 15
device=ACS
objective=allow particular user to have privilege level 15 access to a device except router command
- i was trying to achieve the above but cant. my observation is i cant deny any commands under the config mode. but commands like ping,show,configure which are under the exec mode could be denied easily.
thanks in advance for any help.
1 REPLY
Silver
Re: deny router command on priv level 15
By default, there are three command levels on the router:
• privilege level 0-Includes the disable, enable, exit, help, and logout commands
• privilege level 1-Includes all user-level commands at the router> prompt
• privilege level 15-Includes all enable-level commands at the router> prompt
You can move commands around between privilege levels with this command:
privilege exec level priv-lvl command
109
