Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Depreciated Mibs
I have already opened a tac case.
I need to touch over 10k devices using snmp to set an initial config. I have snmp scripts but want to be sure I do the push with the nondepreciated oid per IOS/OS.
Does anyone know of or have a matrix of IOS/OS oid/mib depreciated by IOS/OS level with the associated replacement oid ?
Not that I have 237 possible IOS/OS's I may come across and using ciscos mib browser to get this information will be tedious.
Silver
Re: Depreciated Mibs
The fact that it is deprecated means that anyone who was not using it before should definitely not start using it now. If they were using it before, they should have noticed the status of the variable. Once they were deprecated and inquired about what new ones were replacing it. Deprecated variables are typically only active for a couple of releases post being marked as deprecated.
Yeah. All your comments are common knowledge.
If I have 237 difference IOS/OS's, I need to know the correct oid to use to push / pull configs. ... and the mib broswer just aint going to do it.
I need a table ...
116
