Detailed Device Report Output
What would cause "Interface Description" to be populated with: FastEthernet0/0 User configured description: fa0/0 1 bg-nb-r1 NORTEL FE).1, in the "Processor Port Interfaces" section of the Detailed Device Report and the very next interface fa0/1, not show any results when an interface description has been defined, shows only FastEthernet0/1?
1 ACCEPTED SOLUTION
Re: Detailed Device Report Output
RME 4.1.1 is part of LMS 3.0.1. RME 4.2 (where the fix exists) is part of LMS 3.1.
This sounds like my bug, CSCsm31447.
Symptom:
The Interface Description for certain interfaces may have the wrong user-configured value, or no user-configured value at all. This can be seen in the inventory reports in Resource Manager Essentials which show interface details (e.g. the Detailed Device Report).
Conditions:
This will occur for devices which have ports that have descriptions that end in a number. If the number at the very end of the description is not the same as ifIndex, then the RME reports will not accurately reflect that description.
Workaround:
There is no workaround.
Will this be fixed in the next release?
It is fixed in RME 4.2 now. I have also written a patch for RME 4.1.1.
On this system, I am currently on rme version 4.0.6...is there a migration path to get to 4.1.1? Or is that a LMS 3.0 version?
227
