09-15-2009 10:07 AM
I'm trying to run a report in RME that will show me what supervisor type my 4500 and 6500 devices are running. I've looked in Detailed Device Report and don't see it either. Any suggestions?
Solved! Go to Solution.
09-15-2009 10:17 AM
There may not be a clear indication of Sup type in the RME reports. RME reports on the SNMP object name of either the module type of the entPhysicalVendorType.
The Cat4K sup IV is cevCat4kWsx4515, and the Sup V is cevCat4kWsx4516.
09-15-2009 10:17 AM
09-15-2009 10:29 AM
Good enough, I can work with that...thanks!
