Device center CDP info on LMS 2.6
eliaspaulos
on Device Center some devices showing wrong(outdated) or no cdp neighbor information.is there any way to re run or update. Many thanks in Advance.
SNMP walk to the devices showing like this...
ifDescr
RFC1213-MIB::ifDescr.1 = STRING: "Vlan1"
RFC1213-MIB::ifDescr.5001 = STRING: "Port-channel1"
RFC1213-MIB::ifDescr.10101 = STRING: "GigabitEthernet0/1"
RFC1213-MIB::ifDescr.10102 = STRING: "GigabitEthernet0/2"
RFC1213-MIB::ifDescr.10103 = STRING: "GigabitEthernet0/3"
RFC1213-MIB::ifDescr.10104 = STRING: "GigabitEthernet0/4"
RFC1213-MIB::ifDescr.10105 = STRING: "GigabitEthernet0/5"
RFC1213-MIB::ifDescr.10106 = STRING: "GigabitEthernet0/6"
RFC1213-MIB::ifDescr.10107 = STRING: "GigabitEthernet0/7"
RFC1213-MIB::ifDescr.10108 = STRING: "GigabitEthernet0/8"
RFC1213-MIB::ifDescr.10109 = STRING: "GigabitEthernet0/9"
RFC1213-MIB::ifDescr.10110 = STRING: "GigabitEthernet0/10"
RFC1213-MIB::ifDescr.10111 = STRING: "GigabitEthernet0/11"
RFC1213-MIB::ifDescr.10112 = STRING: "GigabitEthernet0/12"
RFC1213-MIB::ifDescr.10113 = STRING: "GigabitEthernet0/13"
RFC1213-MIB::ifDescr.10114 = STRING: "GigabitEthernet0/14"
RFC1213-MIB::ifDescr.10115 = STRING: "GigabitEthernet0/15"
RFC1213-MIB::ifDescr.10116 = STRING: "GigabitEthernet0/16"
RFC1213-MIB::ifDescr.10117 = STRING: "GigabitEthernet0/17"
RFC1213-MIB::ifDescr.10118 = STRING: "GigabitEthernet0/18"
RFC1213-MIB::ifDescr.10119 = STRING: "GigabitEthernet0/19"
RFC1213-MIB::ifDescr.10120 = STRING: "GigabitEthernet0/20"
RFC1213-MIB::ifDescr.10121 = STRING: "GigabitEthernet0/21"
RFC1213-MIB::ifDescr.10122 = STRING: "GigabitEthernet0/22"
RFC1213-MIB::ifDescr.10123 = STRING: "GigabitEthernet0/23"
RFC1213-MIB::ifDescr.10124 = STRING: "GigabitEthernet0/24"
RFC1213-MIB::ifDescr.10125 = STRING: "GigabitEthernet0/25"
RFC1213-MIB::ifDescr.10126 = STRING: "GigabitEthernet0/26"
RFC1213-MIB::ifDescr.10127 = STRING: "GigabitEthernet0/27"
RFC1213-MIB::ifDescr.10128 = STRING: "GigabitEthernet0/28"
RFC1213-MIB::ifDescr.10501 = STRING: "Null0"
You will need CS 3.0.6 and CM 4.0.11. These aren't as big as a 3.0 upgrade, but they aren't small. You'll have to bring down LMS, and probably take an hour to do the updates.
As a workaround in the time being, you can reinitialize your ANI database:
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=ani dmprefix=ANI
After a subsequent Data Collection, this problem should be solved.
Joe Clarke
This is controlled by Campus Manager Data Collection. If you haven't upgraded from 4.0.9 to 4.0.11, this information could become stale due to bugs.
thanks J. we have a plan to upgrade to 3.0. I think better to wait!! or it's very small patch
can be done easily. I don't want to do 2 times.
any suggestion. big thanks as always!!!
