10-24-2006 09:07 PM
Hi, I am using Ciscoworks LMS 2.5 on Windows 2003 service pack 1.
Since last week, I am not able to use Device selector any more from all Ciscoworks components (e.g Common Services, Device Troubleshooting, RME etc....)
Could you pls help us to troubleshoot the problem?
10-24-2006 09:13 PM
Moreover, the message in device selector log file:
"SNMP library exception while finding device support"
10-24-2006 10:19 PM
What specific versions of the applications do you have? What changed on the server between when this was working and when it stopped? What do the device selectors look like (i.e. are they completely empty, do they just show folders, etc.)? What is the process state of the DCRServer and the various *OGSServer daemons?
10-25-2006 03:01 PM
We are using LMS 2.5 with Common Serivces 2.5, Campus Manager 4.0.4, RME 4.0.3, Cisco View 6.1.4.
NO there was no change when this was working. Device selector completely empty.
HOw to check the process state?
10-25-2006 03:10 PM
After rebooting the Ciscoworks server, the device selector started working. Thanks for your support.
