11-01-2006 07:05 AM
How can I tell if a device is compatible with certain versions of Ciscoworks LMS?
My customer has a number of End of Life switches and routers on their network. They currently run LMS 2.2 and wish to upgrade to LMS 2.6. They have concerns that they may not get the full benefit of 2.6 with some hardware ie. device packages may not be available etc..
Customer may opt for LMS 2.5.1
Here is a list of their hardware - is it all compatible with 2.6 or can someone point me in the right direction.
cat4500
c4006
c4005
c3750
c3725
c3560
c3550
c3500xl
c2950
c1841
c1700
Help would be most appreciated.
11-01-2006 07:19 AM
Have a look at these support lists for LMS 2.5 modules and you can see if these devices are supported or not:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_4_x/rme405/rme405.htm
11-01-2006 08:35 AM
Thanks - that was just what I was looking for.
Give yourself a pat on the back Davistan.
