Device credentials
At one of our customers we have a LMS 2.5 . For the moment we're adding extra switches on a regular base . This means that I need to take care of the device credentials every time when a new machine goes in production .
Would it be possible that a new device uses by default the settings that I program ?
Since we always the same user it would save me a lot of work ...
gr
wim
1 REPLY
Re: Device credentials
Hai,
Yes it can be done through CM 4.0.
Give the Ip address range and the community strings (provided all your new switches will have same snmp community strings)in which ur switches will fall and schedule the discovery.
Once the discovery and inventory details are retrieved from your new devices it will be automatically updated to the DCR.
Hope this information helps u.
If so dont forget to rate this :)
So if a new switch is addedd
297
