Community Member
Device Discovery in Campus Manager LMS 2.6
I need to do device discoveries for all of our local and remote sites. We have made a lot of changes in the past few months to our network. When I do a device discovery I get old devices that have been removed from our network, Is there an easier way for me to clean up the database without manually  removing the old devices so when I do a discovery it is only reporting devices that it can currently connect to?
T.J.
1 REPLY
Re: Device Discovery in Campus Manager LMS 2.6
I could give you commands to delete all discovered devices but if you run it you will loose ALL historical data like config archive, IPM collector statistics, etc.  If you do not want to loose the historical data from your LMS server, then you need to delete the devices manually.
129
