Community Member
Device Discovery Issue
This is a bit strange and I am hoping that someone has seen this before. The Device Discovery in our LMS install has stopped working. The discovery.log file output is below..
2007/08/31 10:55:24 main MESSAGE DiscoveryMain: Properties will be read from D:\PROGRA~1\CSCOpx\campus\etc\cwsi\DiscoveryStatus.properties
2007/08/31 10:55:24 main FATAL ERROR ServiceModule: undefined property: ServiceModuleList
I read a while ago about discovery stopping if there were more than 200 seed devices, but our LMS installation only has 175 seed devices.
Any ideas and all help gratefully received.
Re: Device Discovery Issue
Can you try the following:
Please go to d:\progra~1\CSCOpx\campus\etc\cwsi directory.
Do a backup of DeviceDiscovery.properties file (rename it to DeviceDiscovery.properties.bak)
Copy the DeviceDiscovery.properties.orig and rename it to DeviceDiscovery.properties in the same loation.
Add the following to the file:
DEVICESROOT=D:\\PROGRA~1\\CSCOpx\\campus\\lib\\classpath
(Please note that DEVICESROOT= may be present in the file so you may
replace that line.)
Restart the daemon manager.
Re-add the seed device and SNMP credentials.
Community Member
Davistan - thanks for the help - stupidly enough I posted this exact same query (which you replied to then as well) in February when I had the same issue. What I had forgotten is the fact that I recently rebuilt the server and had forgot to take the above into account after the rebuild.
I found the old reply, applied the suggested fix from yourself and all is well and working.
Thansk for taking the time to help.
143
