Device Discovery Seed Connect Problem
we were on network one . now after migration we are on other network A.B.26.*. but our seed devices are on other network A.B.25.*
every time i try to start device discovery on LMS 2.6 i get this error (from log)
2010/02/05 12:46:14 main ERROR SMFFactoryLoader: java.lang.NullPointerException
2010/02/05 12:46:14 main ERROR DiscoveryMain: AniStaticConfigException: Error accessing devices--root path , packageName com.cisco.nm.ani.server.devices
complete log attached
BR
Re: Device Discovery Seed Connect Problem
Exactly what version of Campus Manager do you have?
You should really consider upgrading to LMS 2.6 SP1 which includes RME 4.0.6, CS 3.0.6, and Campus 4.0.12.  These upgrades are available from Common Services > Software Center > Software Update.
For this issue, post the NMSROOT/campus/etc/cwsi/DeviceDiscovery.properties.
I want to upgrade but every time i connect this server to internet and try update in the log i see that my name/password is not ok but it is ok. (i dont understand why cant update)
AniName=DeviceDiscovery
Server.version=5.0
Server.copyright=Copyright (C) 1997-2004 Cisco Systems, Inc., All rights reserved
TimeBase.Devdiscovery.Type=Periodic
TimeBase.Devdiscovery.Schedule=1073741823
ServiceModuleList=Devdiscovery
ServiceModulePackage=com.cisco.nm.ani.server
ServiceModule.Devdiscovery=com.cisco.nm.ani.server.devdiscovery.DevdiscoveryServiceModule
TimeBase.Devdiscovery.ThreadPool=Devdiscovery
ThreadPool.Devdiscovery.priority=HIGH
ThreadPool.Devdiscovery.count=48
snmp.maxRows=50000
snmp.threads.min=15
snmp.threads.max=48
snmp.maxRetry=1
snmp.timeoutSecs=6
snmp.retryPolicy=com.cisco.nm.lib.snmp.lib.ExpRetryPolicy
snmp.defaultReadCmty=public
snmp.defaultWriteCmty=private
snmp.getBulkSize=10
snmp.encryptCommunity=false
snmp.EnableMultiple=false
snmp.version2c=on
MibInfo=mibinfo.dat
CommunityFile=discoverysnmp.conf
DEVICESROOT=
DEVICESPACKAGE=com.cisco.nm.ani.server.devices
DeviceConfigFile=devices.xml
DeviceAppConfigFile=anidevices.xml
DB.driver=com.sybase.jdbc2.jdbc.SybDriver
DB.url=jdbc:sybase:Tds:localhost:43443?SERVICENAME=aniDb
DB.dsn=ani
DB.Connection.Timeout=60000
DB.Connection.MinIdleTime=60000
DB.ReaperSleepTime=30000
AniDBNullColumnValidation=false
Ani.sendEvents=false
DB.WriteClassListToDb=false
nameserver.usedns=false
nameserver.useloopbackaddress=false
nameserver.resolveByName=false
nameserver.resolveBySysName=false
nameserver.updateDCRDisplayName=false
nameserver.updateDomainNameSuffix=false
Discovery.router=on
Discovery.seed=157.206.25.190:157.206.25.189:157.206.26.50:157.206.26.51:157.206.26.34:157.206.26.54
LogMsg.logfile=D:\\CW-LMS\\log\\discovery.log
LogMsg.state=enable
LogMsg.threadStamp=true
LogMsg.timeStamp=true
LogMsg.deviceId=false
LogMsg.logFileSize=1000000
Discovery.subnets.include=157.206.26.*:157.206.25.*
LogMsg.deviceList=
LogMsg.trace=frontend:framework:devdiscovery:devices:devices.AccessPoint:devices.AppHost:devices.C1200:devices.C2800:devices.C2900XL:devices.C2900XL.C2900XL_11_2_8_SA4:devices.C2900XL.C2900XL_12_0_5_XP:devices.C2900XL.C2950:devices.C3900:devices.C3K:devices.C5K:devices.C5K.C3750:devices.C5K.C4K:devices.C5K.C4K.C4KIOS:devices.C5K.C4K.C4KIOS.C4KIOS_12_1_13_EW1:devices.C5K.C4K.C4K_5_2_1:devices.C5K.C4K.C4K_5_5_1:devices.C5K.C5500:devices.C5K.C5500.C5500_2_2_1:devices.C5K.C5500.C5500_2_4_3:devices.C5K.C5500.C5500_3_1_0:devices.C5K.C5500.C5500_4_1_0:devices.C5K.C5500.C5500_4_4_1:devices.C5K.C5500.C5500_5_2_1:devices.C5K.C5500.C5500_5_5_1:devices.C5K.C5500.C6K:devices.C5K.C5500.C6K.C3550:devices.C5K.C5500.C6K.C3550.C3550_12_1_11_EA1:devices.C5K.C5500.C6K.C6KIOS:devices.C5K.C5500.C6K.C6K_5_2_1:devices.C5K.C5500.C6K.C6K_5_5_1:devices.C5K.C5500.C6K.C6K_6_1_0:devices.C5K.C5K_2_2_1:devices.C5K.C5K_2_4_3:devices.C5K.C5K_3_1_0:devices.C5K.C5K_4_1_0:devices.C5K.C5K_4_4_1:devices.C5K.C5K_5_5_1:devices.CSS11K:devices.Hub:devices.ICS7750:devices.LS1010:devices.MSS:devices.MSS.IgxBpx:devices.NetScout:devices.Router:devices.Router.C2611:devices.Router.C4224:devices.Router.CE:devices.Router.DSL:devices.Router.MDS:devices.Router.ONS:devices.Router.RSM:devices.Unknown:devices.C5K.C5K_5_2_1:
LogMsg.debug=frontend:framework:devdiscovery:devices:devices.AccessPoint:devices.AppHost:devices.C1200:devices.C2800:devices.C2900XL:devices.C2900XL.C2900XL_11_2_8_SA4:devices.C2900XL.C2900XL_12_0_5_XP:devices.C2900XL.C2950:devices.C3900:devices.C3K:devices.C5K:devices.C5K.C3750:devices.C5K.C4K:devices.C5K.C4K.C4KIOS:devices.C5K.C4K.C4KIOS.C4KIOS_12_1_13_EW1:devices.C5K.C4K.C4K_5_2_1:devices.C5K.C4K.C4K_5_5_1:devices.C5K.C5500:devices.C5K.C5500.C5500_2_2_1:devices.C5K.C5500.C5500_2_4_3:devices.C5K.C5500.C5500_3_1_0:devices.C5K.C5500.C5500_4_1_0:devices.C5K.C5500.C5500_4_4_1:devices.C5K.C5500.C5500_5_2_1:devices.C5K.C5500.C5500_5_5_1:devices.C5K.C5500.C6K:devices.C5K.C5500.C6K.C3550:devices.C5K.C5500.C6K.C3550.C3550_12_1_11_EA1:devices.C5K.C5500.C6K.C6KIOS:devices.C5K.C5500.C6K.C6K_5_2_1:devices.C5K.C5500.C6K.C6K_5_5_1:devices.C5K.C5500.C6K.C6K_6_1_0:devices.C5K.C5K_2_2_1:devices.C5K.C5K_2_4_3:devices.C5K.C5K_3_1_0:devices.C5K.C5K_4_1_0:devices.C5K.C5K_4_4_1:devices.C5K.C5K_5_5_1:devices.CSS11K:devices.Hub:devices.ICS7750:devices.LS1010:devices.MSS:devices.MSS.IgxBpx:devices.NetScout:devices.Router:devices.Router.C2611:devices.Router.C4224:devices.Router.CE:devices.Router.DSL:devices.Router.MDS:devices.Router.ONS:devices.Router.RSM:devices.Unknown:devices.C5K.C5K_5_2_1:
Your upgrade issue is most likely CSCsg47200.  You will need to manually get the CS 3.0.6 upgrade from http://www.cisco.com/cgi-bin/tablebuild.pl/cd-one-3des .
As for the Discovery issue, I need you to attach the file, not post it inline.
many thanks for that link we were not able to find it
for that device discovery:
DeviceDiscovery.properties attached (it without comments - i deleted them in our original file)
Try this file.  Replace your existing DeviceDiscovery.properties with this one.
I owe you so many bears
update is great and discovery is working perfectly
MANY THANKS
367
