12-27-2006 03:10 AM
I have upgraded the LMS 2.5.1 to LMS 2.6 .
I am now trying to install the Device Fault Manager package.I have with the original cds the 2.0.3 . But i get an error message saying ERROR: Downgrade not Supported. Version of dfmad2.0 to be installed is less than already installed 2.0 .
I tryied to download and install the 2.0.4 or 2.0.5 but i cant (2.0.3 is required) .
Any ideas ?
Makis
12-27-2006 06:57 AM
If you select the option to uninstall DFM what options does it present you with?
Do you see either of these:
Device Fault Manager 2.0.3
Device Fault Manager 2.0.3 HPOV-Netview adapters
12-27-2006 07:28 AM
Thanks for your reply .
I havent install the dfm , so i cant uninstall it.
Its the first time i am trying after the upgrade to lms 2.6.
Makis
12-27-2006 07:31 AM
12-28-2006 09:47 AM
Finally i uninstalled the 2.0.6 version that was installed with the LMS 2.6 update.Maybe i had installed only the HP openview adapters , but i couldnt install the DFM after the update.
So from the add/remove programs i unistall only the DFM and started again the installation from 2.0.3 and then update to the latest versions .
Makis
