04-22-2009 01:12 PM
I have run inventory report on RME and got 3 device list by there OID number instead of model(chassis) model name. these are the .EntityVendorOIDType(.1.3.6.1.4.1.9.12.3.1.3.405)(
also this is outdated CISCO-ENTITY-VENDORTYPE-OID-MIB. when I check on CM-> device-update and installed device package list the OID for this model Cisco 3845 is "1.3.6.1.4.1.9.1.544 Cisco 3845 " so why is this the older oid display on Device inventory?
Solved! Go to Solution.
04-22-2009 02:35 PM
This is the ENTITY vendor type OID, not the sysObjectID. This simply means the MIB translation was not compiled into this version of RME. RME 4.2 contains the translation for this OID.
04-22-2009 02:35 PM
04-23-2009 07:24 AM
Thanks a lot, I do understand now.
