Device package for cm for 2911?
Dear *,
When I try to fetch IOS from 2911 I get “SWIM1027: Error while fetching inventory information”. With 2921 I have no problem in fetching IOS. Does anyone know which pkgs to download here to resolve this issue? My server has no access to internet.
Aamir
Hall of Fame Super Silver
Re: Device package for cm for 2911?
What version of LMS and RME are you running?
Generally speaking, you can download the RME package updates (term applies to LMS 3.2 or earlier) on an Internet-connected machine using your CCO login and then manually transfer them offline to your private network Ciscoworks. You'll then need to perform a manual install of the packages. On a Windows server, that is done as follows (assuming default installation locations):
Stop CiscoWorks:
net stop crmdmgtd
Install updates (choosing the relevant apps for your case):
"C:\Program Files (x86)\CSCOpx\bin\PSUCli" -p cmf -install -src c:\psu_download\cmf -all
"C:\Program Files (x86)\CSCOpx\bin\PSUCli" -p cm -install -src c:\psu_download\cm -all
"C:\Program Files (x86)\CSCOpx\bin\PSUCli" -p rme -install -src c:\psu_download\rme -all
"C:\Program Files (x86)\CSCOpx\bin\PSUCli" -p cvw -install -src c:\psu_download\cvw -all
"C:\Program Files (x86)\CSCOpx\bin\PSUCli" -p dfm -install -src c:\psu_download\dfm -all
to uninstall them:
"C:\Program Files (x86)\CSCOpx\bin\PSUCli" -p cmf -u -all
etc.
Start CiscoWorks application back up:
net start crmdmgtd
Then watch for CW server ready directory to empty before attemting to access CW application once again: C:\Program Files (x86)\CSCOpx\objects\dmgt\ready
Hi Aamir,
What version of RME do you have installed? The packages will depend on that.
Once you know your RME version, you can go to the download manager on cisco.com and download device packages for your version of RME.
http://www.cisco.com/cisco/software/navigator.html?a=a&i=rpm
For example, if you have RME 4.3.1 then you would go here:
http://www.cisco.com/cisco/software/release.html?mdfid=282635175&flowid=5145&softwareid=280775121&release=4.3.1&rellifecycle=&relind=AVAILABLE&reltype=latest
And you install the package Rtr2900.RME431.v1-2.zip.
Of course if you are installing manually you will need to ensure all the pre-requisite packages are already installed (this will be listed in the readme file with the package).
Cheers,
Shane
316
