Community Member
Device Update and MDF issue on LMS 2.6
I tried to update my RME 4.0.5 with last packages available. PSUcli sends a error because MDF 1.15 is installed and 1.16 is required. Seee below:
Error while installing LibInventory: e:\PSU_download\rme\LibInventory.zip cannot be installed because, the current mdf version:1.15 is LESS THAN the minimum required mdf version:1.16 Released the Lock... No package(s) to install for Resource Manager Essentials
I don't see MDF update available in cisco.com
How to do?
Regards.
Silver
Re: Device Update and MDF issue on LMS 2.6
Hi Yves-Alain,
the mdf packages are found in the Common Services section here:
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-cd-one
Just download and follow the instruction in the provided .readme (pdf) files.
Hope that helps,
Frank
Community Member
Edit: Didnt see the reply. :)
Thanks, all solved
687
