Community Member
Device update
After patching my LMS 2.6 upto CM 4.0.10 (Solaris 9) I still observe some unwanted behaviour. When I change the name of a switch (also the DNS) this change is not recognized by Data Collection unless I delete such device and start a new network discovery cycle.
Is this normal in LMS 2.6? In LMS 2.2 this is updated automatically. Thanks
Re: Device update
You need to edit your DeviceDiscovery.properties file, and set at least one property to true:
nameserver.updateDCRDisplayName=true
If you want the DCR display name to update with the fully-qualified hostname, also make sure the following is set to true:
nameserver.updateDomainNameSuffix=true
After doing that, the display name should be updated in DCR when a change is detected.
Community Member
Re: Device update
It didn't work, even after restarting the LMS and launching a new discovery and data collection cycle again. Is there anything else I can try?
Re: Device update
Please post your DeviceDiscovery.properties file.
127
