Devices in databases not in reports
LMS 2.5(campus 4.0.3/CS 3.0.3..etc)
ACS integrated-tacacs.
I have 2 devices that are in the DCR
(i.e they show up in CS@servername & RME@servername under Common Services-Device Mgt.) they do not show up in Campus@servername. one does not show up in either the discovery report nor the data collection report while the other one is in both. The one in both also shows up in topology services while the other does not. Tried deleting and re adding to no avail. planning to upgrade to 2.6 soon (long story), is my next step reinit of campus?
Re: Devices in databases not in reports
I have a feeling you're seeing a bug in Campus Manager that is fixed in recent versions. MY recommendation is to first upgrade to LMS 2.6 then to CM 4.0.10 or higher. Then reinitialize the ANI database. After a new Data Collection, you should see your devices correctly.
jclarke- appreciate the info-- I have successfully used many of your posts, just wanted to say thanks!!!
95
