06-16-2009 02:28 AM
Hello all,
I have a problem with LMS.
We had a LMS 2.5, We upgraded to 2.6 last week. After that we have detected some devices aren't supported,(as 3750 or 3020) by RME. We have downloaded and we have installed device packages but it doesn't work.
CWLMS 2.6 W2003 (SP1) amb 4Gb RAM
CS 3.0.6
RME 4.0.6
Any idea?
Thanks in advance
Jose
Solved! Go to Solution.
06-23-2009 07:24 AM
Your package repositories are damaged. There is a procedure to recover from this which involves copying a set of packages from an up-to-date known good server. The TAC can provide these packages and the procedure to correct this problem moving forward.
06-16-2009 08:52 AM
What are the sysObjectIDs of these devices? Exactly what errors are you seeing in RME?
06-18-2009 06:24 AM
06-18-2009 08:43 AM
I need the sysObjectIDs. You can get the sysObjectIDs using the SNMP Walk tool in Device Center. Additionally, I cannot read docx files.
06-23-2009 01:55 AM
06-23-2009 07:24 AM
07-03-2009 12:31 AM
Thank you very much one more time. Your solution solved my problem.
