10-02-2008 10:51 AM
I have dfm 2.0.11 installed on Windows2000 server. When I try to modify/edit my existing notification group, it does not do anything. However, I am able to add a new notification group. Please advise. Thanks in advance.
Pete
Solved! Go to Solution.
10-02-2008 11:39 AM
JRE has nothing to do with it. DFM is all non-Java on the client side. It is more likely an issue of needing to clear your browser cache.
10-02-2008 10:57 AM
What are you changing in your existing group? What errors/pop-ups do you get?
10-02-2008 11:10 AM
I just realize the problem only happened on one workstation. When I try to open the existing group in the localhost of the server and a different workstation, I was okay.
Let me try to un-install and re-install the JRE for that workstation. I will let you know the result. Thanks Joe.
10-02-2008 11:39 AM
10-02-2008 11:59 AM
Okay, empty out the browser cache did it. Thank you very much for your help Joe!
