DFM 2.0.9 Polling control
A customer asked me if it's possible to control the way DFM detects the threshold crossing. On several NNM it's possible to say X crossing occurrences on Y polling cycles, or X consecutive crossing, etc. As there are no details on the docs I am assuming that the algorithm is straight, one crossing triggers an event.
Is there any hidden file where we can change this behavior?
  • Network Management
1 REPLY
Re: DFM 2.0.9 Polling control
You are correct in your analysis. While DFM gives you the ability to set the thresholds, you cannot control the algorithm used to compute the events.
98
