Community Member
DFM 3.0 Problem
I have DFM 3.0 ... I have 5 Devices that are showing Unkown, i can see those devices in Chasis View .... those 5 devices are cisco 4503 Core Switches with SUP II ... i tried to upgrade the devices packages but it gives msg " no updates available for selected products " .. can any body help me what should i do ????
urgent reply willl be highly appreciated
1 REPLY
Re: DFM 3.0 Problem
Check the supported devices table for DFM 3.0:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.0/device_support/table/lms30sdt.html
You will need to check the sysObjectID you get from your device, to that list there. I think it is supposed to support the Cat 4503 if it's running version 12.2(25)SG and returns a sysObjectID value of 1.3.6.1.4.1.9.1.503.
147
