Community Member
DFM 3.1.3 and CATOS switches
After we upgraded our DMF from 3.1.1 to 3.1.3 we get a memory ExcessiveFragmentation error on all Cat OS switches. We have rebooted some of the switches but DFM still report errors on the switches. How do we fix this problem?
Re: DFM 3.1.3 and CATOS switches
What version of CatOS are these switches running.
Community Member
Cisco Systems, Inc. WS-C2948\X0ACisco Catalyst Operating System Software, Version 6.1(1)
and
Cisco Systems, Inc. WS-C4912\X0ACisco Catalyst Operating System Software, Version 7.4(3)
Community Member
I've got the same error with a WS-C6509\X0ACisco Catalyst Operating System
Software, Version 8.2(1).
After this error appears, the CPU switchover without reason.
Is it a linked effect ?
Sorry, I missed this follow-up. If you're still seeing this event, try removing these switches from DFM, then re-add them. DFM should only try and manage the processor and not the memory pools.
Community Member
I have deleted and readded this switches in DFM but I still get the same memory fragmentation error
Post a screenshot of the Detailed Device View for one of these switches. That is found under DFM > Device Management > Device Details.
Community Member
Screenshot attached
I cannot open MDI files. Please post a JPEG.
Community Member
I have done a new screenshot to a JPG file
This is the RME Detailed Device Report. I wanted to see the DFM Detailed Device View under DFM > Device Management > Device Details.
Community Member
The screendump is from the "Print" function in the Detailed Device View in DFM and not from RME.
I have done a new sceendumt without use of the "Print" function
You should not have a Memory section for this device. Post your NMSROOT/objects/smarts/conf/discovery/oid2type.conf file.
Community Member
File posted
This all checks out. I cannot reproduce locally (i.e. my 2900 CatOS switches do not have a Memory category). I recommend you open a TAC service request so the developers can take a look at this.
Community Member
Sbrox did you get anywhere with the TAC on this one per jclarke's direction? I have noticed we have the same thing showing up now that we've upgraded.
We have a few CatOS boxes around that are showing this.
Community Member
Joe,
Sorry to bug about this issue but I thought maybe you would notice this and be able to give some input. I have opened a TAC case #612766109 about this.
So far I was advised to raise the threshold to five which it was already at. I went ahead and raised this fragmentation threshold to 10 but it will seems to be causing an alert. Is there anythign else I should do to put this case going in the right direction?
FYI here is an example DFM event:
MANAGED OBJECT TYPE = Switches and Hubs
EVENT DESCRIPTION = ExcessiveFragmentation::Component=MEM-*.*.*.*/9 [CLUSTER];ComponentClass=Memory;ComponentEventCode=1030;FreeMemory=7468 KB;TotalMemory=7480 KB;FragmentationThreshold=10;FreeMemoryPct=99.83957219251337 %;LargestFreeBuffer=2 KB;LargestFreeBufferPc
277
