DFM 3.1.3 errors - Urgent please
Hi to all
I have a strange situation for my DFM. All the devices that i tried to put in DFM are stuck in learning. Also i got this error (error1.jpg) when i try to access DFM>Config>Other Config>Alerts and activities> or this error (error2.jpg) when i try to open DFM>Config>Pooling and Thresh
All the proccess are OK, running normally in CS>Admin.
Also in NSROOT\log\dfmlog i see almost in evry log this error:
"Error in getting instance of TreeGenerator class com.cisco.nm.trx.kdm.utils.DcrGroupSelectorTreeGenerator Root Cause:com.cisco.nm.xms.ctm.common.CTMException: URN_NOT_FOUND : urn "ogs_server_urn" : Not found "
Re: DFM 3.1.3 errors - Urgent please
Post the output of the pdshow command.
Hi Clarke
Here is the output of the command.
and the attachement
This looks fine. Post the DFMOGSServer.log and DFMOGSClient.log along with the logs under NMSROOT/log/dfmLogs/PTM.
There is no such files in the PTM directory (see capture). I found those log files in NMSROOT\Log directory.
Also i attached DFMLogServer and DfmLogService.
There is certainly something wrong with DFMOGSServer, but the log doesn't indicate what that is. More debugging will be required. Given the timezone difference, I suggest you contact TAC to get more realtime help with this issue.
Ok. Thanks for reply
166
