06-12-2009 05:00 AM
When I unmanage an interface in device details the state will return to "true" and faults will appear in the AA window.
I also get the window that says I need to apply changes, but that doesn't help the issue.
Is this a bug that can be patched?
Solved! Go to Solution.
06-12-2009 08:56 AM
This is bug CSCsz08953. A patch is available from the TAC to correct the issue.
06-12-2009 08:56 AM
06-12-2009 12:01 PM
Since I recently upgraded to DFM 3.1.3 I'm also experiencing this issue.
Can you advise where I can get the fix please.
06-12-2009 12:17 PM
As I said, a patch is available by contacting the TAC, and referencing the aforementioned bug.
06-12-2009 02:00 PM
Thanks. Just wanted to be sure before I called TAC. Didn't want to call them if it was available via download.
Out of interest, do you know why these types of patches aren't made available via download and why they need to be requesed via TAC??
06-14-2009 10:10 AM
They have not gone through the typical testing cycle, and thus are not posted to Cisco.com.
