Webcast-Catalyst9k
DFM 3.2.0 - Questioned Device
After trying to manage a WS-C2960S-48TD-L switch in DFM i'm getting the following error -
    *** Data Collector Status Information ***
Error Code                   = Others
Error Message             = response from VIC is not compliant
I'm running -
LMS - 3.2
DFM - 3.2.0
DFM Device Update - 10.0
Any ideas?
Cheers
Tim
Re: DFM 3.2.0 - Questioned Device
CS MDF1.42 ?
you have that installed and running IOS12.2.50 min?
Thanks for your reply.
MDF 1.42 is installed and the switch is running  IOS Version 12.2(53)SE2
sry - no more ideas ...
According to the following link:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/device_support/table/lms32sdt.html
the device should be compatible.
Can we upload the 'show diag' of the device?
podhillo
203
